Actually, i have a question. Will the graphics card in the original post fit? As i noticed it is a GDDR3 and the mobo seems to be DDR2. Does this matter?
*cough*. Um, yes. GDDR is different to DDR anyway. The only DDR2 cards youll find are suspiciously cheap ones with large numbers next to them, graphics companies being slightly immoral there.
As long as the card fits in the case, you've no worries. Looking at your case, it might not. Worth finding a review before purchase.
Oem drives dont come with cables, but the motherboard *should* come with at least two. Again worth reading a review on it really
How does the 4850 compare to the 4770? I know little about current graphics cards, but the 4770 seemed to generate enormous excitement
