Everything i need to make my own cables
26 Dec 2010
London
Hi everyone,
I've spent the last week or so looking up how to sleeve my cables and then how to make them, but it's been little bits of info here and there, i need some confirmation that im not making any mistakes.
- 18AWG wire (how thick is this? can i use it for all my wires?)
- Molex Pin and Socket Crimps (Do the females go into the plastic connector blocks? and if so how does it work)
- What can i use to secure the crimps?
- Heat shrink (What size should i get? and what is shrink ratio?)
- Sleeving braid (I want a braid that is not see through at all, and just black)
any feedback is really appreciated thanks
big first time project to take on. its a very tedious job, very time consuming as well
also to do it right you really want to be investing in "good tools" probably talking £100 + parts then you wire+ quality sleeving.
3:1 heat shrink is the most commonly used. Also a lot dont use it not 100% necessary.
