Cooling stands oddly enough. Most use whatever fans happen to not be shifting that month on shelves that don't allow much airflow and so nothing really happens except the section a nice space where clutter can be avoided and cables can be set beside.
http://www.coolermaster.com/cooling/notepal-series/masternotepal-maker/
My current one is a precursor to the above with a usb 2.0 hub at the side and adjustable stand angle with 2 80mm fans that do nothing really except make noise.
My current plan is to take a pack of these:
https://www.overclockers.co.uk/cors...netic-levitation-fan-dual-pack-fg-056-cs.html
Mount them diagonally at opposite angles forming a tent shape. I'll dremel where the fans sit except for the holes that will let me mouth the fan and use a coarse fan filter instead.
I'll bolt below on some salvaged parts from my GS30 dock, namely:
Aquaero LT to control the fans via USB interface
Aquaero farbwek for RGB underlighting (strip under the back of the machine)
I'll then mount 3 temperature sensors:
1. under the laptop to monitor air in temperatures
2. CPU cooling vent
3. One of the GPU cooling vents (the heatsink is a single vapor chamber so it should all be even)
That way I could make the dock change colour as the machine warms up and start spinning up the fans when it's under load. Since the intakes are at either side I could also separate which sensors are controlling which fan.
Will it do much? No idea, but it should look fancy enough
2. CPU cooling vent
