Hey guys,
So I think I'm pretty much mind made up on EVGA as a manufacturer solely down to the warranty they offer, but this leaves me in a tricky situation. I'm also pretty set on the 1080 Ti rather than just the standard 1080, but I've noticed all of the EVGA cards are currently 2 slot, not the normal 2.5 slot most others are - and my worry is with regards to noise (less optimal cooling).
My current setup is 2x 290's, but both are watercooled so as you'd expect it's pretty silent. I guess I could put a block on down the line (I'd have to check to see if EVGA allow it, or factor that into initial cost), but otherwise, I'm wondering how the EVGA 1080 Ti's are for noise?
And also further on from that, I see there's 2 main differing ones - the SC Black vs the SC2 Gaming - not really sure what the difference is aside from the cooler, which one would be best?
I can't really find much anywhere!
And if you think of anything else I've glaringly missed, or something wrong, please let me know
Matt
Matt
