Evga 1200 p2 or superflower 1200w platinum
The EVGA is made by SuperFlower and is based on the Leadex, so they will both be very similar in reliability and performance.
The SuperFlower unit has white LED connectors which don't appeal to everybody. You can see them in the listing. You can't turn them off either.
You also can't get aftermarket braided cables as yet for the SuperFlower (They are supposedly in the pipeline). You can buy Cablemod kits from OCUK for the EVGA P2 if you want different coloured cables.
I would probably go with the EVGA if I was buying myself, but they are both excellent units.
