EVGA 570 superclocked
Well just to give you an indication of how powerfull this EVGA card is i completed a few benchmarks using 3DMark 11 on my PC.
Palit GTX580 reference card.
EVGA GTX570 HD SC.
I set my CPU to stock, as i wanted the test to be as fair possible. My CPU maxed out at just over 3Ghz both times.
My stock GTX580 scored 5466
EVGA GTX570 scored 5275
I then took the EVGA GTX570 to 822/1644/1950 score 5353
Max temp with todays outside temps was 85 :) really pleased with the temp to be honest, fan maxed out at 51%
Just had a little run around on BLOPS, (3 maps DOMINATION) max temp was 75 max fan was 48%
Very impressed with this GPU tbh.
Decent scores for stock cpu, i think i scored 6500 ish with my cpu at 4.2GHz and a stock 580 if i remember, never ran that bench with stock cpu, with that same 580 overclocked (they do overclock just like 570's :P) i got around 7800.
Edit: Just looked up my results and it was 4.25GHz on the i7 950 and stock v overclocked on the 580: Stock - P6550 Overclocked - P7816.
