EVGA 680 MCP Temperature is very hot!
23 Mar 2007
Kent, UK
I've just got my new PC put togeather and it's been running for a couple hours just sat at a boot failure prompt.
I've just checked the temps in the bois and getting the following...
CPU: 23
Mobo: 25
MCP: 87
I don't have the chipset fan installed as its really really loud! This sounds extremely hot... is this going to cause problems?
Well that's done the trick, my MCP is down to 41 and the fan at 50% isn't too noisy... Wish I could overclock but OCUK sold me a rev 1 board, can't do a decent overclock with my QX6700 without it hanging.
V|per said:
err, evga will replace your board free of charge... go get a rev2 :)
Nope not any more they stopped that on the 30th April. I would have to send the board off to EVGA and wait for a replacement... which will probably take weeks... I'm really annoyed because competitors have the board for the same price and it is the newer version. I've requested a refund from OCUK and ordered the newer version from a competitor.
I doubt you'll get a refund from OCUK unless it's been just 7 days since you received it. Did it explicitly say it was a rev2 when you bought it?
No it didn't say anything, but the point being that I've looked at other sites and they are all selling the A1 board (rev 2) and they all stated that. OCUK don't say and they are still shipping the AR version (rev 1), if they are still shifting old stock while every other website are selling new stock IMO they should at least have the courtisy to tell you that when you buy.
rezza said:
where do u check the MCp temperature from?
If you go on the system monitor screen in the BIOS, it gives you CPU/Board/MCP temps, fan speeds etc. I'm sure you can probably get these from within Windows too.
