Hi, I've just posted this on the EVGA forums, but I thought I would post here also to see if anyone knows the solution. So below is a cut a paste. Thanks in advance.
Just go the A1 revision.
It came with the P26 bios. I'll be upgrading old hardware later, but for now I have two PCI cards slotted in: GForce-6200 and a HighPoint Rocket 133 ATA133 controller with latest bios for that card.
Now initially when I switched the system on for P26 bios revision: the Rocket card was recognised, saw its bios boot screen, which recognised the ATA hard drives. The bios listed, the SCSI device, so I could select to boot from the HD. However, the problem was it would never boot. Just got BIOS FF code, and nvidia check media cable messages.
So, I upgraded the bios to P30. Now the card is no longer recognised. I've tried both PCI slots. The card still works as I've tested in an old system. I put in my previous ATA controller, a Promise100TX2, in the motherboard and it detected that (saw its Bios boot screen, detect HDs etc). But again same problem, could not boot from the HD.
Plugging both HDs 1x1 into the motherboard itself I can boot from them.
The whole reason I have the Rocket is because it is vista compatible, and I need to use my dvd burner (not connected at present) on the on-board IDE ATA port.
I need help! Can I roll back to a previous bios? (if it ever downloads off of the ftp site)
Suggestions please.
Thanks in advance
The hardware in my system:
2 x 1GB OCZ-8500 SLI edition memory
An Antec Quattro 850W PSU.
A Intel Duo E4300
Suggestions please.
Thanks in advance
A Intel Duo E4300
