Heya, I'm looking to upgrade my memory. I have the EVGA 680i board and I'm after a little advice. I'm looking for 4gb as I'm using 64bit vista. Budget is £200~ish. I've been poking around the site And I've considered the 2x2gb OCZ Reapers or going down the 4x1gb route and getting the Dominator 8500. I dont intend to overclock right away but it's certainly something I'm interested in doing eventually(I'm a novice o/cer). System is used all day between lite work and surfing but it is mainly a gaming rig so eeking out all the performance I can get would be fantastic. I don't get any change from the £200 either so I may aswell try and use it all(I can stretch to £250)
cpu is the q6600GO(pumping this upto 3ghz when new hsf arrives), GPU is 8800GTX.
