- 6 Aug 2007
Hi ppl ive got a bit of a wierd problem in that ive installed the board etc and everything went well until i got to setup when i got the C1 message and a long beep every 20 secs i found out after messing around with my Geil 1gb modules that fitting one in the second slot from cpu did the same until i got to the third slot from cpu and it went to boot so i then thought it might have been a glitch/error so i replaced the other slot in the first slot and C1/beep again so i took out the module and tried the 2nd slot same C1/beep until i put it alongside the 3rd module in the 4th and final slot and bingo! but is this right? i mean im only on my third pc build and arent they supposed to be slot 1 and 3 or with a gap?
Or could it be my Geil isnt Sli compatible?
Many thx if you can assist?
TcM
TcM
