It might be the minimum enforced on the bios of the card...but you could always try using MSI Afterburner to see if it allows you to reduce the fanspeed.
Hi, it is the minimum voltage used already. The fan on that model is a voltage controlled one and going down more will not work. What you could try in that case is to install an aftermarket cooler or install a 4Pin Fan you connecto to the motherboard.
I've got this card and at default idling it is (to my ears) silent, maybe something wrong that an RMA would fix?
