There will not be any issue. The third heatpipe you can see is a small one and just to spread the heat a little better between the different cooling parts, it is for sure not a design issue.
Hi, they will get shipped from the Munich office till the end of the week so should be available in UK early/middle of next week.
the 2x 8mm ones do exaclty match the GPU. The third small one is to share the heat between the blocks. The 2 big pipes do cover the whole chip. We tried also a spreader above all three pipes but this did not work as efficient as the direct connection of the pipes.
