EVGA Bridge/SLI question
Permabanned
4 Sep 2011
Durham
I have the Asus Maximus VIII hero board and I've just added a second TX to it. I quite fancy one of those fancy bridges for no other reason than...just because! Just wondering if anyone else is using one of these bridges and will I need to get a long or short version?
Ive had a google about and it seems they are adjustable but although I still cant see how they adjust?
Iirc the spacing on all asus Z series boards of late is 70mm between the sli fingers on gpu's.
Depends on the slot spacing. I would measure the slot gap with a rule or roughly at least. SLI bridges should have slot measurements in the specs.
Think I read that as well. Second TX arrives tomorrow so I will get it measured u once its installed
Im going by a maximus 6 formula that i used to have. Same spacing as the 6 hero. And all ROG boards since look to have a similair spacing. Iirc the widest spaced Z series boards from asus are the pro models.
