EVGA Classified SR-2 motherboard
26 Mar 2010
London
This looks very appealing.
We are proud to present the EVGA Classified SR-2, the absolute ultimate for the extreme user. It takes everything that made the X58 Classified 4-way SLI motherboard great and doubled it up. Now you can experience the ultimate in overclocked multithreaded performance by way of Dual 1366 sockets which allow for hyper-threaded Intel Xeon CPU’s to be combined together for massive amounts of workload to be spread across a multitude of processing threads.
When combined with compatible Intel 6 Core CPU’s, you create a massive system capable of up to 24 CPU threads of compute power. If you want future-proof, this is it!
We have literally created a new form factor to fit all the amazing things on one board. Whether you are an extreme gamer, overclocker, power user, workstation user, server admin, folder/cruncher, or just a PC enthusiast; this is the ultimate motherboard. This board will encode your movies, render your images, or even load your games faster than you ever thought possible.
If this takes Xeon processors it should be able to take i7 too right as it says supports socket 1366. Also can this mobo run on one cpu or does it need two to run? It's bigger than an XL-ATX MOBO too lol.
i see motherboard manufacturers are starting to go way over the top.
i can see this board costing £450 easy.
Your probably right if they ever bring it to UK as everything is always at least 30% more expensive than in US. EVGA's MSRRP is $600 US dollars. Although I'm gonna stick with the UD9, I can't afford to buy two xeon cpus at £800+ each.
