EVGA DG86 Build
22 Oct 2002
Cardiff
Hi
After a some serious thought recently I've decided to update my case and WC, it currently is just the CPU that's cooled as i've never been able to find a compatible GPU block till now. I will try to re-use everything bar the existing case and WC setup.
CPU - i7 6950x - 4.2Ghz
Motherboard - Asus X99 Deluxe 3.1
RAM - Corsair Vengeance DDR4 32GB 3000 C15
GPU - Zotac AMP Extreme GTX1080
PSU - Superflower 1200W Platinum
HDD's - Samsung SM951 512Gb, 2 x Samsung 840 EVO 500Gb (RAID 0), 3TB Seagate HDD
Monitors - Dell AW3418DW & Dell U2711
Soudcard - Sound Blaster ZxR
OS - Win 10 Pro
WC Case - Corsair 650d
- EK-CoolStream PE 240
- EK-Supremacy Clean CSQ AceNic
- EK RES D5 Vario + PUMP
New items
Case
- EVGA DG-86 Full Tower Gaming Case
CPU Waterblock
- EK Asus X99 Monoblock (Already Purchased)
GPU Waterblock
- Bitspower ZOTAC GTX 1080 AMP Extreme Clear Acrylic
Rads
- EK-CoolStream CE 420
- EK-CoolStream XE 360
Pump
- EK Water Blocks EK-XRES 140 Revo D5 RGB PWM
Tubing
2m EK-Tube ZMT Matte Black 16/11mm
Fittings
- 10 x EK Water Blocks EK-ACF Fitting 12/16mm - Black
- 2 x EK Water Blocks EK-AF Angled 45 Degrees G1 / 4 inch - Black
- 2 x EK Water Blocks EK-AF Angled 90 Degrees G1 / 4 inch - Black
Fluid
EK Water Blocks EK-CryoFuel Clear Premix 900 ml
Fans
- 3 x EK Water Blocks EK-Vardar EVO 140ER Black (2000rpm)
- 3 x EK Water Blocks EK-Vardar EVO 120ER Black (2200rpm)
Extra's
- 6 x EK Water Blocks EK-Cable PWM Extension Cables Sleeved (30cm)
- 1 x Silverstone SST-PP07-EPS8BR EPS-8pin to EPS/ATX-4+4pin 300mm, Black Red
- 1 x Silverstone SST-PP07-MBBR ATX 24pin to MB-24pin 300mm, Black Red
- 2 x Silverstone SST-PP07-PCIBR PCI-8pin to PCIE-6+2pin 250mm, Black Red
This is my current thought process for layout, please let me know what you think.
Cheers Chris
