EVGA FTX570 SC
30 Jan 2008
EVGA GTX570 SC
I've got one the above and want to SLI it. The problem I'm facing is that I can't find one of the damn' things to pair it with.
Do I have to use another 570 running at the same clock settings, or can I pair up with a boggo GTX570 and have them sort themselves out? (or manually OC the stock card up to the same settings)
It's OC profile is:
797Mhz GPU Clock Speed
3900Mhz Memory Clock Speed
if this helps. Thanks all
I would get a card certified at similar clockspeeds and flash it with the EVGA bios of your current card (use GPU-Z to make a bios image).
Or you could get a bog standard card and just flash your EVGA with the bog standard bios from that, that way you might get less problems due to overclocking the lesser card and you're unlikely to notice a difference of ~70mhz with SLI anyway.
