Evga G2 Cables
I think the likes of Cablemod (another brand is mentioned on here quite often as well but I can't remember the name) will do single cables but you have to buy direct from them. Are cable extensions of any use? They just plug onto the ends of your current cables and fit all psu's. The Phanteks and Bitfenix ones are good and reasonably priced. If I remember right the Phanteks ones come with cable combs too.
