What the difference between these two EVGA 1080 GPU's as the spec looks the same ?
But the Classified costs about £70 more
Surely am not that bad at spot the difference
EVGA GTX 1080 "Classified"
https://www.overclockers.co.uk/evga...s-graphics-card-08g-p4-6188-kr-gx-299-ea.html
Specification:
- RGB LED
- 10+2 Power Phase
- Backplate
- Dual BIOS
- GPU: GeForce® GTX 1080
- CUDA cores: 2560
- Video Memory: 8GB GDDR5X
- Memory Bus: 256-bit
- Engine Clock Base: TBD MHz
- Boost:TBD MHz
- Memory Clock: TBD MHz
- PCI Express 3.0
- Display Outputs: 3 x DisplayPort 1.4, 1x HDMI 2.0b, 1x DL-DVI
- HDCP Support: Yes
- Multi Display Capability Quad Display
- Recommended Power Supply 500W
- Power Consumption 180W
- Power Input 2x 8-pin
- DirectX 12 API feature level 12_1
- OpenGL 4.5
- Slot Size 2.5 Slot
- SLI Yes
- Supported OS Windows 10 / 8 / 7 / Vista
- Warranty: 3yr
GeForce GTX 1080 FTW
https://www.overclockers.co.uk/evga...s-graphics-card-08g-p4-6286-kr-gx-300-ea.html
Specification:
- RGB LED
- 10+2 Power Phase
- Backplate
- Dual BIOS
- CUDA cores: 2560
- Engine Clock Base: 1733 MHz
- Boost:1873 MHz
- Memory Clock: 10,010 MHz
- PCI Express 3.0
- HDCP Support: Yes
- OpenGL 4.5
- SLI Yes
- Warranty: 3yr
