EVGA GTX 1080 TI FTW3 LED Colours & EKWB Block Question
25 Sep 2012
England
So I received the beast of a GPU, and it's performance is outstanding, even the temps, considering its not under water yet and in a glass case.
LED Colours
The temperature LEDs do not seem to actually distribute, as if all you can see is the LED Itself. Does anybody else have the same issue?
zSbEYYqf2dl4nxATQpy2eiOw9sUy-KaAHg8di4iykwyQZ1UjjY0MswaZ5iViZootkDWfqVS6J87d1r1kcrMjiXBfSGflweYd5lzDXRXooP3xW4Ee80L16Pxs8Tx7CzVFtAFSgqv-2Nsmj7v2G_eJ1HJ2Kqq7rj6d_LpfXnMl4uMaGzX05l_Wj3QTaWEN6Cv49NqKOc3KJ0cchNKmP2SXfyIuYMuZyiQOZ7rhe1BVAJ0BKTT4eZr1yf9iF0c4IT6J7ZGocc0tTJlhH8TWwgT-NrobhWwU73gFB0ppk4YCA5VNmfSxsHmC_Ob0UUeYz9CIXNDkeTJLq_c9hBX06gBPRN5Mgk1qjS49_0CwazzHHFHAb6uTP8Y4tyqSSTOIO1OxvBqK_I01H6tnAxQRCQ67gzmq7WW_wuksjkDBxhG27Y7OKXmxbkDgGsqNaLplFbrjhHLEvZ-2XtICVQMLLv5-oj1zOjpDT6AnKCGJn0ZptQZjGN37tkj9SxgC6NSv2t9vyDF6mpo-2lmPt9MXXSGLJNHrZE9v40YxdM3-QZQKLASnHSGsGMyN3kZJRKpUn-FpeIFWeBA_ulTW_nR5Gyqt1qV09Knd_g_q7T-gO6RSv3F3Wg1uISFjMvVOow=w1747-h1310-no
Aside from this, there are LEDs which seem to shine onto the cooling fins, which really ruins the look in my opinion. This could be related to the Purple Colour scheme which results in the Blue colour being the most predominant which turns the cooling fins on the card blue.
These obviously won't be an issue when they're put under water as its all removed anyway.
EKWB Block Question
Secondly does Anybody know the size of the GPU with the EKWB on? as I'm looking at it now and not sure if this GPU would fit in my case (Lian Li PC-08) with the WC Block on.
