EVGA GTX 760 2GB BF4 Optimal Settings Help?
16 Dec 2013
Ok so i purchase a GTX 760 2GB recently and i was wondering what are the best settings i could use on BF4 for best performance and optimal FPS and what not?
Any help would be deeply appreciated! <3
Would it be the preset medium or custom settings with medium and some settings turned off?
Also will an overclocked CPU benefit to the performance of BF4?
The 760 is about the same as a 670, I use ultra everything with my 670 except for hbao i turn off. This gives me over 60 fps average and perfectly playable. It depends on your cpu if it is worth overclocking, Although i have my 3570k at 4.2ghz, this might make a difference in the minimum fps.
Some People with AMD 290's and 780's play BF4 at low settings with vsynch off as they like over 100fps all the time.
Need some more information really, I've struggled a lot to get BF4 to feel "smooth" but pretty much there now.
Whats the rest of your system like? Especially
CPU + the speed of it
Ram?
Resolution?
I've found upgrading to windows 8 has helped, as I've read it's better optimized
Than win7.
Also dl the geforce experience as it will pick the best settings for u
