EVGA GTX 780 reference backplate
Quick Google showed nada. Evga do have good forums with responsive moderators, so you can ask them explicitly there. If you’re ok with a non-evga branded backplate there are also several on a certain well known auction website.
FYI this thread is in the wrong sub-forum dood, should be in the GPU section. Sure a mod will move it eventually though.
Sadly these are very difficult to source since the 780 and 780 Ti are discontinued.
I tried recently to get another for my SLI config, in the end I googled 'custom gtx backplates cold' and purchased one from the top result.
You could always get a custom backplate from cold zero. Haven't had anything from hum, but from what i have seen, his work and designs look top quality!
Try Dominik Ungermann at the EU office hes helped me in the past failing that you could ask on the evga forums,ill keep a eye out for one for you bud.
