Item due on 15 November 2011 seems to have popped up today, dont know if anyone has seen these?
Nice clocks and o/c potential, bit pricey tho.
EVGA GTX 580 Classified, 40nm, 4212MHz GDDR5, GPU 855MHz, Shader 1710MHz, 512 Cores, 2x DL DVI-I/ EVBot
Performance
NVIDIA GTX 580
512 CUDA Cores
855 MHz GPU
1710MHz Shader Clock
Memory
3072 MB, 384 bit GDDR5
4212 MHz (effective)
202.1 GB/s Memory Bandwidth
Interface
PCI-E 2.0 16x
DVI-I, DVI-I, EVBot
SLI Capable
Resolution & Refresh
240Hz Max Refresh Rate
2048x1536 Max Analog
2560x1600 Max Digital
Key Features
2-Way SLI® Support
3-Way SLI® Support
X-Cool Switch for Extreme OC Mode
4-Way SLI® Support
Microsoft DirectX 11 support
NVIDIA CUDA technology
NVIDIA PhysX technology
NVIDIA 3D Vision Surround Ready
NVIDIA PureVideo HD technology
PCI Express 2.0 support
Two dual-link DVI-I connectors
Dual-link HDCP-Capable
Microsoft Windows 7 Support
OpenGL 4.0 Support
HDMI 1.4 connector
EVGA EVBot Support
This product comes with a Limited Lifetime warranty with registration within 30 days of purchase.
Operating System Support
Windows 7 32/64bit, Windows Vista 32/64bit, Windows XP 32/64bit
Requirements
Minimum of a 600 Watt power supply.
(Minimum recommended power supply with +12 Volt current rating of 42 Amps.)
An available 6-pin PCI-E power connector and two available 8 pin PCI-E power connectors
"I wanted a graphics card that overclocked to hell and back without limits," said Vince "k|ngp|n" Lucido. "With the EVGA GeForce GTX 580 Classified, we were able to reach GPU clockspeeds at over 1.6GHz."
"With the EVGA GeForce GTX 580 Classified, we focused on the key elements that the GPU and Memory need when overclocking. Power, stability, noise ripple reduction and extreme OC mode without limits. The design was created with overclocking in mind." Said Illya "TiN" Tsemenko.
The EVGA GeForce GTX 580 Classified is engineered and designed to perform for everyone, from gamers to the top overclocking enthusiasts in the world. The dual slot top cooled design means that you do not need to worry about space or motherboard layout limitations, and this card supports everything from single card up to 4-way SLI out of the box.
I imagine OCUK will be getting a few of these in?
Performance
NVIDIA GTX 580
512 CUDA Cores
855 MHz GPU
Memory
Interface
PCI-E 2.0 16x
DVI-I, DVI-I, EVBot
SLI Capable
Key Features
2-Way SLI® Support
3-Way SLI® Support
4-Way SLI® Support
OpenGL 4.0 Support
HDMI 1.4 connector
EVGA EVBot Support
Requirements
