evga gtx295 problems question
30 Nov 2007
I have an eVGA gtx295 on order, and i am very excited.
Thing is, ive been on the evga forum and there seems to be a reasonable ammount of threads regarding issues and problems with this card, not posting, lockups, dots, sli, and flickering to name a few.
I know that the forum is a worldwide forum and doesn't relate to just one country but is this something i should be concerned about ? is this a problematic card ?
For everyone who posts a problem factor in the loads of people who never post because they don't have a problem, there will be 1000's world wide so think of it that way.
Just ordered one my self :D it's gonna be fine mate ;)
I was thinking of buying one of these cards too. Bit of a noobish question so I apologise in advance. Do you have to enable SLI in the nvidia control panel or is it considered a single card?
Exactly, and how obvious is that answer! Mine runs perfect BTW.
SLI will be enabled by default. You can disable it if you ever wanted to use just one GPU though.
i also have one only problem i get is , some games not supporting multi gpu but all you do is go into nvidia control panel and create a custom setup for the game.
only issue i have is when i need to have the game in a window with voice comms programs etc open, but thats only in Everquest 2 which is old now, but it works 100% in full screen mode.
other than that software issue, the card is flawless
