Evga gtx770 tdp question. Maybe a question for 8pack?
11 Mar 2014
Hi guys, I've got a evga gtx770 sc acx with an xspc water block. Under full load overclocked it boosts to 1358mhz at 109% tdp. If I go any higher it starts throttling back same if I increase the memory speed. On the evga precision HUD the max you can set the tdp is 106% and the voltage to 1.2v. Is there any way with this or another program to let it run a slightly higher voltage or tdp whichever it needs as temps under full load don't even hit 50 deg c.
Many thanks in advance, Damien.
You need to flash on a 3rd party BIOS that will help increase the power limit. While I don't know correctly about extended volts on the 770, I would imagine the usual rbby trick on Afterburner should work since Unwinder did not treat the GTX 770 like a 3rd party card (which was the case with the 780 Ti).
Ok thanks for your reply. I don't want to go to extremes like that flashing bios and stuff as I'm not experienced enough to do it properly. 1358mhz is still a decent gtx770 clock tho isn't it? It's just a shame I can't take it a little more as it's not the quality of chip or temperature holding it back.
