EVGA Hybrid question!
7 Aug 2012
Hi. Have an EVGA 1080SC which is decent and the ACX cooler is pretty good and remains largely inaudible. However, I have a slight fancy for getting 1 of the hybrid kits if/ when the EVGA store get stock.
Now I see that the pump and fan connect to the GPU's fan header. However, from what I can gather, using Precision or Afterburner for controlling fan only controls the blower fan for the VRM chips and doesn't control the rad fan, which I gather spins at a constant speed?
Now, I also have a Corsair Commander Mini - could I, in theory plug the rad fan directly in to that and set up a fan curve using Corsair Link to control the rad fan?
Probably a silly question tbh, and a negative wouldn't hinder me at all, but would be nice if could fit a PWM fan and have it spin right down to say 300-400rpm at idle and then increase as the GPU temp increases!
I have two SP120 Quiet Edition (PWM edition fans) on my rad, work very well connected to my fan controller. On my fan controller they don't go under 900rpm, but it's silent at that speed anyway.
