EVGA P2 PSU Cables - length query
10 Oct 2003
Nottingham
Hi,
I want to buy some custom cables for my new pc but I've spent ages routing all the cables currently as they are too long and so they are all zipclocked or tied up in my case - so reluctant to remove them to measure.
I don't suppose anyone could tell me whether the length that EVGA specify on their site (eg 600mm 24pin, 700mm eps/cpu) is just the wire length? Or is it the full cable length including the connectors? PSU is EVGA SuperNova P2 750W. Checked the EVGA site but its not clear
Thanks!
What are the lengths and ill measure and check against my p2 850w.
however if youve already ties them up and put them out the way why you wanna change them? should always use stock if you can IMO. my htpc i HAD to buy horter ones as yesh theyre hella long and was already cramped as hell in there so got 15cm gpu ones and 30cm mobo.
