http://www.evga.com/precision/
Improvements over 4.1.0 (lots)
Key Features
•GPU and Memory Frequency/Clock Offset
•Power Target Control (GeForce GTX TITAN / 700 / 600)
•Temperature Target Control (GeForce GTX TITAN / 700)
•Pixel Clock Overclocking – OC your refresh rate!
•Frame Rate Target Control
•GPU Voltage Adjustment + Overvoltage (GeForce GTX TITAN / 700)
•Custom Fan Control/Fan Curve
•Profiling system allowing up to 10 profiles with hotkey
•Robust monitoring allowing ingame, system tray and/or Logitech LCD monitoring
•In game screenshot hotkey, supports BMP, PNG and JPG formats
•Custom skins including ones created by the EVGA community!
•Support for wireless Bluetooth overclocking via custom Android app
•Multi-language support: English, Dutch, French, Traditional Chinese, Japanese, Korean, Polish, Russian, Spanish, Portuguese
•New Default Skin, legacy skins are available from the Options > User Interface tab
•Improved NVAPI access layer architecture with better extendibility
•Improved hardware monitoring module architecture with better extendibility
•Added temperature limit, power limit, voltage limit, maximum overvoltage limit and GPU utilization limit graphs to hardware monitoring module for release 320 and newer NVIDIA driver. The graphs help you to understand the reasons of realtime performance limitations (e.g. limiting performance due to reaching power target) on GPU Boost compatible graphics cards
•Added framebuffer, video engine and bus controller usage graphs to hardware monitoring module
•Added generic NVAPI videomemory usage monitoring for NVIDIA graphics cards unattached to Windows desktop (e.g. dedicated PhysX accelerators)
•Updated power reporting for release 320 and newer NVIDIA drivers. Now EVGA Precision X reports normalized total power according to NVIDIA recommendations
•Now RivaTuner Statistics Server installer is being started by EVGA Precision X installer to make installation process easier for beginners. The server distributive is being copied to .\Redist\RTSSSetup.exe during EVGA Precision X installation, so you may always install it later if necessary
•Added workaround for missing tray icon when starting application while EXPLORER.EXE is not responding
•Application tray icon is now being restored after restarting EXPLORER.EXE
•Build number is now displayed in “i” window and in application tray icon tooltip
•Localizable installer files for third party translators are now included in distributive in .\SDK\Localization\Installer folder
•RivaTuner Statistics Server distributive has been upgraded to version 5.1.2: ◦Added update checking system
◦Added version checking system to installer. Now the installer is giving you a warning when you’re trying to install older or reinstall currently installed version of the server
◦Added client notification system to installer. Now the installer is notifying client applications like EVGA Precision in the end of the server installation process to allow the clients to restart themselves
◦Added workaround for missing tray icon when starting application while EXPLORER.EXE is not responding
◦Application tray icon is now being restored after restarting EXPLORER.EXE
◦Fixed issue with newly added profiles not being automatically selected in the profiles list
◦Added keyboard navigation support for profiles list
◦Added On-Screen Display profile for Medal of Honor: Allied Assault
◦Improved reboot notifications for locked files installation/uninstallation
◦Now RivaTuner Statistics Server prevents attempts to start application without rebooting the system in case of using delayed locked files update scenario during installation
◦Added screen capture support for fullscreen Direct3D7 and DirectDraw applications (windowed mode is not supported). Please take a note that DirectDraw and Direct3D7 hooking is disabled by default in global profile, it is recommended to enable DirectDraw and Direct3D7 hooking at application profile level instead of enabling it globally
◦Build number is now displayed in application tray icon tooltip
◦Localizable installer files for third party translators are now included in distributive in .\SDK\Localization\Installer folder
◦Updated profiles list
•Now RivaTuner Statistics Server version is displayed in “i” window
•Now it is possible to override group names for values displayed in the On-Screen Display or in Logitech keyboard LCD display
•“Show system time” option now longer depend on On-Screen Display header or any hardware monitoring item visibility
