EVGA Pro SLI Bridge Availability
3 May 2016
Newcastle UK
Anyone know what the score is with the EVGA Pro SLI Bridge availability (not the new 10 series HB version)?
I have tried all the places I can think of in the UK and everyone is out of stock.
Which one specifically?
I was looking the other day and found each variant aside from the 60mm bridge which is the one I needed.
Ended up getting the new NVidia one instead.
If you are looking for the non 60mm one, I can maybe trust you some places in the UK and EU where I found them.
Tried flea bay - no good.
I am looking for the 2-way long version (3 slot gpu spacing?).
Does the NVidia SLI Bridge have the same performance as the EVGA Pro SLI Bridge - it will be fitted to my two EVGA 980ti
Yeah that is the 60mm one which is quite hard to come by.
The EVGA pro HB and the Nvidia HB bridge are basically the same in terms of connecting to both of the SLI headers, although 980ti's don't utilise both from what I have learnt.
Should still see noise reduction over SLI and micro stutter reduction over a flexi bridge though.
