- 24 Mar 2004
- kintyre
whats your opinions on this deal ? and those that have used it whats the roll over times like ?
lordfletch said:whats your opinions on this deal ? and those that have used it whats the roll over times like ?
davecarter said:Imo 3 months is way too short , I mean who upgrades their graphics card every three months
Greenboi said:Is it a straight conversion from USD to GBP? if so i can upgrade my GTS 320 to a GTX for £61, which i will be doing if its that cheap!
Yes, that is one amazing card, its won best of 8800 series in a few roundups, i was thinking about upgrading to it but worked out far too expensive and since the 7900gs is handling most things at modest settings i decided against it.Greebo said:Ignoring the step up though, it is worth buying an EVGA card especially the ACS3 versions so long as you don't pay too much over the odds.
They have a great warranty (10 years) and is the the only (i'm sure somebody will correct me if wrong) manufacturer who honours the warranty if you overclock the card.
Plus the ACS3 coooler is better than the standard nvidia cooler so in theory you ought to get better overclocks.
Mines now at 650 core and 2200 memory and I still feel it has further to go on the core but i'm going to use some artic silver first before trying for more.
Nope, they use their own recommended retail price which is ALWAYS higher than you can get from a retailer.Greenboi said:Is it a straight conversion from USD to GBP? if so i can upgrade my GTS 320 to a GTX for £61, which i will be doing if its that cheap!
