- 28 Aug 2011
- Glasgow, Scotland
quoted from the EVGA website, you can purchase them there so i chose to leave the link www.google.co.uk + EVGA Z68 *** w/ EVGauge and ECP V4.
i have not fully read this but i am liking the sound of these, im still debating to chance it or wait for other people with more experience to give some reviews and pointers
Take Control
The EVGA Z68 motherboards have arrived! These motherboards based on the latest Intel Express Chipset offer incredible performance and overclocking with Intel Core i5 and Core i7 processors, and with the new Intel Smart Response Technology, users can combine a Solid State Drive with a traditional mechanical drive and receive both high performance and high storage capacity! Intel Smart Response Technology implements a storage I/O caching system to provide users with faster response times for frequently used applications.
The entire EVGA Z68 lineup has full support for SATA III/6G and USB 3.0 giving you the latest standards in high performance storage, and a forward thinking true next generation motherboard layout allows you to take control!
Why Choose EVGA Z68?
EVGA Motherboards are well known for their features and overclocking capabilities. The new EVGA Z68 motherboards are based upon the award winning EVGA P67 designs, here is what customers had to say about them:
"I went from the (ASUS P67) Sabertooth to the (EVGA P67) *** and am very happy I did." - dmbatch
"Although I have to say, a lot of work and time was put into the board. The looks and the bios are very nice." - DJ Ray
How about professional editors? Overclockers Tech said this:
"You will be hard pressed to find another P67 motherboard out there that can outperform the P67 ***."
EVGA Z68 Features:
Bonus Storage (Z68 ***)
Integrated Flash Storage
Use as storage, swap file, anything!
12 Phase PWM (Z68 ***)
Pulse Width Modulator
Cleanest possible variable power switching
EVGA Vdroop Control
What you see is what you get
Set your voltage in the BIOS and this is what you will get under load booted in your OS
EVGA Dummy OC
Overclock at the touch of a button
Automatically overclock your system with one simple setting in the BIOS
EVGA E-LEET Tuning Utility
Overclock your motherboard from inside your OS
Use E-LEET to test your OC settings without having to constantly restart into your BIOS
EVGA EZ Voltages read points
Simple voltage points
Easily read voltage levels using a voltmeter with several dedicated read points
Onboard Clear CMOS, Power and Reset Buttons
System essentials at the touch of a button
Troubleshooting and bench booting are simple with these controls
300% More Socket Gold + Low ESR/ESL Film Cap (Z68 ***)
Socket bling
The highest quality materials means you will get the absolute cleanest power to the CPU
Onboard CPU Temp Monitor
Monitor your temps quickly and easily
Accurately and instantly see your CPU temperature once your system has completed POST without any other software.
Passive Chipset Heatsink
No fans: lower noise and longer lifespan
More than enough cooling wattage to keep those chips well within specs
Triple BIOS Support (Z68 ***)
Backup, compare and more!
No matter what you do to one BIOS, you will always have two more backups instantly available
Solid State Capacitors
Higher quality, longer lifespan
These high quality 100% solid state capacitors will just keep going and going
EVGA ECP Support
External debugging
You never again have to open your case to see your debug code, disable PCIe jumpers and overclocking options too
PCIe Disable Jumpers (Z68 ***)
Instantly troubleshoot
Test a multi-card system instantly and water cooling systems without having to disassemble the loop
Part Number: 160-SB-E689-K2
CPU Support: Intel Socket 1155
Chipset: Intel Z68
Memory Support: Dual Channel DDR3
SLI Support: 2-way & 3-way SLI + PhysX
SATA Header: 4 x SATA II, 2 x SATA III/6G
SATA Type: 3G/6G
USB Ports: 12
PCIE Slot: 5 x PCI-E x8/x16, 1 x PCI-E x1
Integrated LAN: 2 x 10/100/1000
Product Warranty: 3 Year warranty
EVGA Z68 ***
Part Number: 160-SB-E689-KR
Chipset: Intel Z68
SATA Type: 3G/6G
USB Ports: 12
EVGA Z68 SLI
Part Number: 130-SB-E685-KR
Chipset: Intel Z68
SLI Support: 2-way SLI + PhysX
SATA Type: 3G/6G
USB Ports: 12
PCIE Slot: 2 x PCI-E x8/x16, 1 x PCI-E x4, 2 x PCI-E x1
EVGA Z68 SLI Micro
Part Number: 120-SB-E682-KR
Chipset: Intel Z68
SATA Type: 3G/6G
USB Ports: 14
PCIE Slot: 2 x PCI-E x8, 2 x PCI-E x1
