EVGA Z87 Classified Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Welcome to a new class of high performance motherboards with the EVGA Z87 lineup. These platforms offer a return to greatness with a completely redesigned GUI BIOS interface, reimagined power VRM that focuses on efficiency, and loaded with features like up to 4-Way SLI, Creative Sound Core3D quad-core audio processor, Intel Gigabit LAN, Native SATA6G/USB 3.0 and more.
Did we also mention that this motherboard is designed for the overclocker? Built from the ground up to give you all the essentials you need for overclocking, with a GUI BIOS that is focused on functionality, brand new software interface for overclocking in the O.S., ultra high quality components, and robust PCI-E 3.0 and memory trace layout.
With these features and more, it is clear that the EVGA Z87 motherboards are not engineered to just be the best, they are engineered to exceed the best.
Key Features
- 300% more gold content in the CPU socket
- 4-Way SLI® Support
- 100% Solid State Capacitors
- EVGA Vdroop Control
- EVGA E-LEET Tuning Support
- EVGA EZ Voltage read points
- Triple BIOS Support
- Creative Sound Core3d
Specifications
- Intel Z87 Chipset
- 4 x 240-pin DIMM socket, Maximum of 32GB of DDR3 (2666MHz+ in dual channel configuration)
- 5x PCI-E x16 slots in (1x16, 2x16, 3x8 or 4x8 configurations)
- 1x PCI-E X1
- 1x mSATA/mPCIe
- 8 x Serial ATA 600MB/sec (8 Internal) with support for RAID 0 and RAID1
- 6 Channel Creative Sound Core3D
- 2 x 10/100/1000 (Intel i217/i210) LAN
- 12 x USB2.0 ports (4 external + 2 internal headers)
- 6 x USB3.0 ports (4 external + 2 internal headers)
- EATX Form Factor
- Comes with a 3 year limited manufacturer warranty. Registration is recommended
Only £329.99 inc VAT.
ORDER NOW
Key Features
Specifications
- Intel Z87 Chipset
- 1x PCI-E X1
- 1x mSATA/mPCIe
- EATX Form Factor
ORDER NOW
