- 28 Oct 2010
- Colchester
Hi guys and girls,
I've been watercooling my computers now 2years or so and love it. I wanted to start my a new build with a red and black theme, as i have done a blue and white theme and a black blue theme.
Over the last month or so i've started to order bits and pieces and toda my last order came through the post, my fans and lighting but i was a little bit grr over that i was sent the wrong fans due to them being out of stock, but i sort of like them anyway.
My kit what i have;
i5 2500k overclocked to 4.6ghz
z68x-ud3p-b3
2 x gtx 580 3gb
8gb ram 1600mhz
60gb ssd
3 x 2tb hdd
blu ray player
I think thats about it for what i can remember.
my watercooling kit;
1 x ek 360 rad
1 x black ice sr 360 rad
1 x ek 240 rad
1 x koolance rp-452x2
2 x D5 pumps
1 x 3meter uv red tubing
16 x compression fitting
6 x viper fans
4 x BitFenix Spectre fans
1 x ek cpu block
2 x ek gtx 580 blocks
1 x 5lts distilled water
(I think thats everythink)
Its a fair wack of kit imo.
Here are some pictures of my kits so far;
This fan can shift some air through i was shocked and love it
Same again with fan, it can really shift some air through.
Sli birdge, could'nt work out if it was 1 slot or 2 so i ordered both, lol.
Cant forget my little helper, he is only 9weeks old 2morrow.
They are the only picture i have for now. I plan to start my build on sunday when im next off work.
The only thing i've got left to do is, flush the rads and put it all together
If you want too look at my other builds they are in my sig.
Thanks for looking
My kit what i have;
z68x-ud3p-b3
2 x gtx 580 3gb
8gb ram 1600mhz
60gb ssd
3 x 2tb hdd
blu ray player
1 x ek 360 rad
1 x ek 240 rad
2 x D5 pumps
6 x viper fans
1 x ek cpu block
.If you want too look at my other builds they are in my sig.
Thanks for looking
