Evolv ATX Watercooling Options?
22 Oct 2012
The Moon
Hi,
I've been using the Noctua NH-D15SS on an X99 system installed in the Evolv ATX Tempered Glass Edition. Unfortunately, the cooler hangs over the clip for the first PCI-E slot which makes inserting cards a bit troublesome. I was wondering what the options were for installing a CLC like the NZXT Kraken. I've heard conflicting messages if he X62 will fit in the roof, and believe the front install requires the 3.5-inch bays to be removed, which isn't ideal. Could you recommend an option for the best solution when it comes to water cooling in this case?
Thanks.
