Permabanned
- 28 Sep 2018
Hi, looking to potentially move away from my HafX and get something new, functional and aesthetically pleasing. It's a notable investment for something new so I really want to get some feedback around it. Worst case, I can stick with the hafx which is still the GPU cooling king.
I've been going through a lot of reviews online and came to an understanding that these 2 cases would work well if the goal is to water cool the CPU.
Option 1:
My basket at Overclockers UK:
Option 2:
The cost difference is trivial.
Configuration for Dynamic:
-Vert gpu since it provides a notable benefit here: https://www.gamersnexus.net/hwreviews/3285-lian-li-o11-dynamic-review-benchmark-der8auer-case-design
-3 x 120mm side fans
-AIO top mount with exhaust
Configuration for EvolvX:
-Vert gpu https://www.gamersnexus.net/hwreviews/3379-phanteks-evolv-x-case-review-dual-system-thermals
- 3 x 140mm front fans
8086k @ 5.0ghz (maybe going to 9900k)
windforce 2080ti overclocked
1TB SSD
ATX mobo z390
What I'm looking for is what setup will cool the GPU the best and keeps things stable for years to come. If I use Gamernexus as a baseline for comparison, the CPU cooling seems similar for both and with the GPU in vert mount both see a benefit. However, the Dynamic benefits more from a Vert GPU in GPU and CPU configurations. The big question is how, how does that change when you put 3x140mm fans in front for the Evolv X instead of 2?
Option 1:
- 1 x Phanteks Enthoo Evolv X Digital Midi Tower Glass Gaming Case - Galaxy Silver= £209.99
- 1 x Phanteks 300mm Slimline PCI-E x16 Riser Cable 180 Degree Adapter= £29.99
- 1 x NZXT Kraken X62 AIO Water Cooling Unit - 280mm= £132.95
Option 2:
- 1 x Lian-Li PC-O11 Dynamic Midi-Tower - White Window= £114.95
- 1 x Lian-Li O11D-1 PCI-Express Riser Cable - Black= £54.95
- 1 x Corsair ML120 Pro RGB 120mm Premium Fan with Lighting Node - Triple Fan Pack= £89.99
1TB SSD
ATX mobo z390
