Welcome to my Project Log, this isn't a fully new build but rather moving to a new case, fans, colour scheme, and design all mixed in with some lovely water cooling! the other reason for this project is I have always wanted a Phanteks, and the Air240 isn't wide enough for my water cooled 980 so the side panel doesn't fit correctly and as you can see from the picture below I have it going to GPU -> CPU, this mixed in with the max 900rpm fans that still noisy mean I cant overclock anything at the minute so something is needed to be done! Bringing me this project!
Current PC:
Components in my Build:
Intel I7 4790k @ 4GHZ
OcUK Gtx 980 @ stock
16GB (8x2) teamgroup @ 2666mhz
Crucial MX100 512GB x2 (1 O/S, 1 Steam)
Asus Impact VII ITX
Silverstone 600W
Current Cooling:
Corsair Air240
6 x Parvum Systems F1.0
XSPC EX240 x2 (1 multiport)
Mayhems Orange Pastel
Alphacool Cape Fuzion Core 10
EK-DDC 3.2 PWM with Acetal DDC top and heatsink
bitspower matte black fittings
hardline tubing
New Cooling:
EK Furious Vardar x2 3000rpm
EK Vardar F4 x2 2200rpm
EK Vardar F2 x1 1450rpm
Primochill CTR compression Tube Reservoir
From the current setup
XSPC EX240 x2 (1 being multiport)
Hardline Tubing
And the Star of the show the Phanteks Evolv ITX
