EX58-UD5 bundle problem?
Status
Not open for further replies.
26 Oct 2003
Hi,
just bought the Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 4.00GHz Max / Gigabyte EX58-UD5 Intel X58 Motherboard / Corsair XMS3 6GB PC3-12800C9 DDR3 / Corsair H50 Bundle
and built my new system with this bundle however, the system seems to keep turning itself off, and when i power up the display does not come on, I have to hold the power button in until it turns off, then power it up again, then i am faced with a problem saying your system was unable to boot due to overclocking issues due to ram voltages or power?
any ideas?
Thanks
UD5's seem to have a problem with sleep mode , mine does but i dont use sleep, i belive some of the later bios have resolved the issue. I would still post in the customer support section and let the guys earn their money ;)
do the guy's at oc know there stuff? Because everyone ive seen on here who's baught an oc system has had problems! Its cheeper an easier to buy the bits and oc urself! Have you also checked the bios settings? As they might need slightly altering?
yes thanks
90% of the time, 'unstable bundles' are down to user error
each bundle undergoes a lengthy testing procedure
you will only see the complaints here but i can assure you that they pale into insignificance compared to the amount of bundles we have shipped to happy customers
cellpack - could you please post in the RMA and customer support forum so that i can assist you properly.
just a quick reminder guys, if you have an issue with an OcUK product, please use the correct support channels so that we can deal with it quicker, the forums are not a support channel unless you post HERE
Status
