Excecl gurus - Finding data in cells
10 Apr 2004
I basically have columns of data for the responses of systems, I need to find the settling time of the systems in each column of data.
This means I have to find the *last* time there is a value outside of 98-102% of the desired value.
VLOOKUP finds the first, I need to find the last.
Ideas?
Yep sounds fine. Do you have a sample spreadsheet and ill do it for you?
Will post the code publicly once done aswell
