Has anyone ever exceeded their PSUs capabilities while overclocking, and what effects did it have?
I was pushing my cards earlier seeing how far they would clock up in GTA and they were running fine at about 1.36v but i think i might have overheated the PSU maybe causing the current to drop a little or summat as my screen went red and the graphics card drivers wouldnt load after i reset so i needed to reinstall them.
Got it running fine again and thought it was maybe just too low voltage on the core so i added a little and tried again. A few hours later i got the red screen again and this time the PC wouldnt post on either bios. I managed to get into the bios after leaving the battery out for a while and reflashed them and got it working again, reinstallled the graphics drivers again and its all up and running again.
The main reason i think its maybe the PSU causing it is cause the only other time i got that red screen crash was when i first got the PSU and i left that Eco mode on so the PSU just overheated after about half an hour all the time, so i had to disable Eco mode to stop that. Also i dont get the same issue if i push one card too far, just get the usual driver crash and artifacts.
Anyone else get any of these results from pushing their PSU a little far?
900w out a 750w is very impressive. I think superflower are suppose to be the best. I think 8 Pack had the 1600w pulling nearly 2000w and the 2000w pulling over 2300w no problem
