Excel 2003 formula help
10 Jan 2006
Newton Aycliffe
Hi i'm having a bit of bother with excel, i've been tearing my hair out the last hour or so trying and failing to work this out
i have a table showing equipment states(Fit, Ltd and U/S), these are auto populated from another sheet using a VLookup formula, i need a formula to work out when the cell D4 in this case is showing the value "FIT" then the cell next to it D5 will auto populate with a number, lets just say for example FIT=10, LTD=5 and U/S=0. please put me out of my misary my brain is completely stumped i'm sure its sitting there staring at me in the face but its just not coming to me.:(
any help on this issue will be greatly appreciated!
=if(d4="FIT",10,If(d4="LTD",5,if(d4="U/S",0)))
That will work problem is 2003 is limited to 8 nested "if" functions so if you have more then 8 conditions then you will have to use another method.
