- 13 Dec 2006
Hi guys,
Firstly I've looked on Google but can't find anything relevant so thought i'd ask you lot, bare with me on this as it might seem a bit confusing.
I am getting two error messages the first is about check your spelling of the filename as it cannot be located. The second says try clicking file > save as which is what we are doing.
If we try to save the file in to a certain folder it comes up with these errors but if we try and save in to another folder in that root folder it works fine. If we try to create a new excel file/folder we get the same error messages.
We can save to the desktop and move the folder in to the required folder but this isn't really any good as we should be able to save in to the folder anyway. This is on a networked machine on a domain.
Hope that makes sense if anyone can suggest anything or needs more specific info let me know.
thanks.
thanks.
