Excel 2013 - insert if condition met
6 Mar 2008
Stoke area
Hi all,
I have a csv file with 2300 entries in it that are lists of addresses.
However, like most addresses they vary in the amount of information they have.
I need to select a column, for instance, column E, then if it has "England" in the cell I need to insert a blank cell and shift them right.
Anyone know how to do this in bulk instead of manually?
I think VBA is the only way to automate this. The following should work, you just need to alter for the ranges you want, and what value to check for.
Code:
Sub shiftRightIf()
    For Each cell In Range("E1:E10").Cells
        If cell.Value = "England" Then
            cell.Select
            Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
        End If
    Next
End Sub
With your CSV file open, in Excel goto visual basic editor, add a module and then paste this code. You should then just be able to run it like a macro.
Hi,
Just to clarify....
You have a column for each line of the address, and if this is the case the "Engalnd" is always moving?
Ignore... ^^
Regards
