Excel and time calculations
5 Feb 2006
Hi, Im trying to write an excel worksheet to record my working times. Im slowly learning the basics but one thing im really not sure of is how to make a formula to do time calculations.
What Im trying to do is enter a start and end time in 24 hour clock and then have excel calculate the number of hours worked and display as a decimal.
e.g. 1400 start, 1945 finish would give 5.75.
Anyone have an idea how to do this?
if cell A1=1400 & B1=1945 then your answer = (TIME(B1/100,MOD(B1,100),0)-TIME(A1/100,MOD(A1,100),0))*24. You may have to change the number format to number with 2 decimal places
I have been using the above formula for awhile now and it works great but I was wondering if there was a way of modifying it so if the hours go over to the next day it would still work. Mainly due to having to work the odd nightshift.
example : start time 2030, end time 0300. Using the present formula this would give -17.5. I need it to give 6.5.
Any help would be great as Im not to good at excel stuff :)
