Excel, Auto sort a colomb
1 Dec 2004
S.Wales
I have a colomb in excel, ranging from G4- G23 which i have sorted in ascending order, but everytime i change some data, it does not automatically update the sort. Is there a way to do this??
Iv search but the only way i can find it is by doing Macro's..
Also would like to have different cell colours for the ranges of the value...e.g..red for values ranging from 1-10, Orange for 10-45 etcl... can this be done? keeping in mind it will need to be updated easily..
Disclaimer - there may be easy ways of doing this, but this is what I use.....
(you'll need to change a fair bit of it)
The auto sort would be easy to do with a vb macro assigned to sheetchange i.e....
Private Sub Workbook_SheetChange(ByVal Sh As Object, _
ByVal Source As Range)
Worksheets("Sheet1").Range("G4:G23").Sort _
Key1:=Worksheets("Sheet1").Range("G4")
this may be over complex and its not tested but should give you some hints.....
For Each cell In Sheets(chartname(NAMEOFSHEET)).Range("G4:G23")
If cell.Value < 10 and cell.Value > 0Then
........cell.Interior.ColorIndex = 6
........cell.Interior.Pattern = xlSolid
Else
........cell.Interior.ColorIndex = 3
End If
Next cell
end sub
So to start off, view code of the worksheet, i have pasted this..
End Sub
Do i need to amend anything to that?
I want to get the autosort working first..
QUOTE]
Made a small mistake. Paste this instead...
Private Sub Worksheet_Change(ByVal Target As Range)
End Sub
that will work when you update it, but only for the range g4:g23 if you want more sorted use g4:g9999 e.t.c..
Still dont work...Iv added that code to the sheet1 code, saved it, tried updating a cell and it dont work..
Do i need to amend any of that code you gave me??
Have you definitely added it to the sheet1 code ?
It works for me.
or you could add...
to the sheet1 sheet object - under worksheet and then change.
Is your sheet called sheet1 ?
what version of excel are you using ?
[Sniper][Wolf] said:
Yep its defenalty right, im using MS Office 2003 with Excel 11.53...
Are you getting any error messages then ?
If not, then the code is probably in the wrong place. You could try and put a message box in the code to see if the message comes up. If not, then it's definitely in the wrong place or macros are disabled.
I've sent a mail to address in your trust.
For anyone interested...
should be....
Worksheets("Sheet1").Range("A4:G23").Sort _
which will sort the whole sheet according to column G which is what the OP wanted.
Conditional formatting is probably best achieved using "Conditional Formatting" on the Formatting menu.
It's quite simple to use and can be copied and pasted about as well.
I never knew that ! Can you apply it to a whole row though according to a cell value ?
