- 24 Sep 2005
- Middlesbrough
Is it possible to create a macro which will create a combo box in cell A1, insert the entries for the menu and then go on to do the same with A2, A3, A4 right upto A450?
I can create this macro but I just can't get it to continue onto the next row into the position that I want it. Also the box needs to enter a number into a cell on the same row.
So A1 will enter a number into $P$1 depending on who is selected from the menu.
A2 will enter $P$2
A3 will enter $P$3
Thanks.
Apologies if it's a little confusing
A2 will enter $P$2
A3 will enter $P$3
Thanks.
