Okay, I realise I use this board a lot for excel help but seeing as it's full of helpful people I shall continue!
I'm trying to do something which I think it quite complicated but hopefully isn't!
My result is calculated as follows. If the Data + 20% column equals less that Data + 5 then the result is Data + 5. However, if the Data + 20% column equals more than or the same as Data + 5 then the result is Data + 20%.
The result column is therefore calculated with a formula, for example C2 is: =IF((B2>(A2+5)),B2,(A2+5)). Okay that's fairly simple.
Now for the complicated bit. I want to do two things. First, I want to conditionally format the Result column so that if the result is false i.e., A2+5 then it turns the text red. And if the result is true i.e., the number from Data + 20% then the text remains black.
The next thing I want to do is count the number of instances in the results column where the result is false.
Can anyone help? I can use the conditional formatting command to format one cell but I have no idea how to apply the formatting to all other cells in the results column so that the formatting changes for the row the result is on. It's very annoying - and obviously the data I am working with is not as above but hundreds of rows.
This is not homework, it's real work.. sadly! It's not in my job description either, but I'm just giving it a go - with someones help, I hope.
