Excel Conditional Formatting problem
26 Feb 2004
Hampshire, England.
Hi guys,
I'm having a lot of bother presenting some really simple data :o
Basically, I want to make a simple financial model that highlights whether a particular venture is making any money or not?
I'd like to highlight the actual value red if it falls under 80% of the target value, highlight orange if equal to the target value and highlight green if above the target value. I've tried using conditional formatting but I'm not sure how/if this scenario would work?
Sales.
Target: 500
Actual: 100
Over/Under: -400
Any ideas?
You would use formula based conditional formatting and 3 rules
So if the target value is in cell A1 and the actual value is in B1, click conditional formatting on cell B1, new rule, "use formula to determine which cells to format" and then for the formula =$b$1<($a$1*0.8) and then just set the format to red
then another rule where b1=a1 and another where b1>a1
Just the ticket, thanks mate ;)
