- 18 Apr 2004
- Milton Keynes, UK
I have a dataset that spans around 50+ columns, however the names are all under a cell in row 2 separated by commas. Example:
For A2, you can see the full string as its the same in each cell in E2, I can use Data > Text to Columns and separate this fine into row 3 for instance. Then using the copy and right click and transpose option.
However, is there a better way to automate and/or do this for the rest of the cells in row 2? Note there's over 50 columns to do... any help appreciated peeps. Thank you.
![Excel-transposing.png](https://i.ibb.co/c8k5wYk/Excel-transposing.png)
![Excel-transposing-2.png](https://i.ibb.co/T0bymGR/Excel-transposing-2.png)
