Excel - Could not load an object...?
5 Mar 2007
Macclesfield
Hello,
I’ve inherited a Excel worksheet and asked if I can “make it work”. It has some Macro’s that can add lines of predetermined data. However, when I click the “Add” button (runs a particular Macro) I receive a message:
“Could not load an object because it is not available on this machine”
Is this as self-evident as it sounds? As in am I actually missing a file?
If I ignore this and try to continue I see a Visual Basic “Compile Error: Can’t find project or library”?
Can anyone suggest a solution or confirm I am missing a required file? (the person who built the spreadsheet has left the company)
You are either missing an activeX control file somewhere, or maybe some of the required libraries aren't selected in the VBA references menu.
I don't mind taking a look if you are able to post the code somewhere.
Need to see the code really but a shot in the dark...
In the VBA window if you go to Tools > References you might need to enable something in there, try "Microsoft Scripting Runtime"
