Excel countifs help
2 Nov 2013
Hi everyone
I have a spreadsheet in which column A has a country name, and then other columns have dates in them (or have #N/A).
is there a way to simply count how many dates there are against a country in a particular column?
I get as far as:
=COUNTIFS('tab name!A:A',"China",'tab name!B:B,????)
But what do I enter for the ???? to say "is a date", or possibly "Is not #N/A"?
Thanks in advance for any help you can offer!
(If that's too easy for you - is it possible to get it to count the dates against a particular country across multiple columns?)
There is no inbuilt function to check if a cell value is a date.
Easiest thing to do without writing a UDF is to check if it is not n/a:
=COUNTIFS('tab name!A:A',"China",'tab name!B:B,"<>#N/A")
Cheers. I suspect that while the #N/A entries originate from a formula, they have been copy-pasted as text entries. Will that still work do you know?
You could alternatively use ">0" as the criteria as all dates should be stored as the number of days since 01/01/1900 and therefore must be a number greater than 0. The #N/A won't be counted.
That would work fine so long as you don't actually have numbers in the column.
Form ultiple columns just repeat your formula with the other cell references
=countif(...)+countif(...)
