7 Aug 2008 at 10:10 #1 mattyj1085 mattyj1085 Associate Joined 27 Feb 2006 Posts 1,750 Location Normanton Does anyone know what formula I can use to convert a time in excel e.g 10:30 into text 10.30??? Cheers
7 Aug 2008 at 11:29 #2 GravyMonster GravyMonster Soldato Joined 18 Oct 2002 Posts 16,220 Location The land of milk & beans in the formatting box, choose custom, then enter hh.mm
7 Aug 2008 at 11:32 #3 mattyj1085 mattyj1085 Associate OP Joined 27 Feb 2006 Posts 1,750 Location Normanton I need it to be stored as the number 10.30 not a time value.
7 Aug 2008 at 12:16 #4 GravyMonster GravyMonster Soldato Joined 18 Oct 2002 Posts 16,220 Location The land of milk & beans What's the calculation you're doing on the value? I assume that's why you need it as a string anyway
7 Aug 2008 at 12:45 #5 mattyj1085 mattyj1085 Associate OP Joined 27 Feb 2006 Posts 1,750 Location Normanton don't know to be honest its one of our users that wanted to know
7 Aug 2008 at 12:55 #6 monkeysmith monkeysmith Associate Joined 3 Jun 2005 Posts 952 Location House Set as number with 2dp?
7 Aug 2008 at 13:10 #7 mattyj1085 mattyj1085 Associate OP Joined 27 Feb 2006 Posts 1,750 Location Normanton cant do as its in time format it changes it to for example 10:30 in time to 0.44 in number
7 Aug 2008 at 13:15 #8 Manlove is my forte Manlove is my forte Soldato Joined 18 Oct 2002 Posts 9,637 Location Xbox Live You can use find and replace to find : and replace it with . ie 10:30 becomes 10.30.00 Haven't figured out how to get rid of the .00 at the end though.
7 Aug 2008 at 14:24 #9 SimonCHere SimonCHere Associate Joined 24 Jun 2008 Posts 1,168 Easy =TEXT(A1,"hh:mm:ss") Simon
7 Aug 2008 at 14:45 #10 mattyj1085 mattyj1085 Associate OP Joined 27 Feb 2006 Posts 1,750 Location Normanton thats it thanks mate
